Little BGP help please
Oct 14th, 2008
We currently have two ISPs that we BGP peer with and before this last weekend this wasn't an issue.
This past weekend we swapped our primary and secondary ISPs. We also changed from VRRP to HSRP (not an issue).
I thought I configured the routers properly but I either missed a step or have something configured wrong.
Here is what I'm trying to do:
Primary ISP will be just that, our primary ISP. 100% of traffic needs to move across this connection with our secondary connection sitting idle just waiting for us to failover to it.
BGP with our both of our ISPs is established. The issue we seem to be having though is that we are getting inbound and outbound traffic on our primary ISP but we are also getting inbound traffic on our secondary ISP but no outbound. We need to have ALL traffic come in and out the primary ISP.
Here is a stripped config:
Primary router:
router bgp 40xxx
no synchronization
bgp log-neighbor-changes
network 198.108.x.x mask 255.255.254.0
neighbor 67.38.x.x remote-as 71xx
neighbor 67.38.x.x description Bronson (40xxx) to SBC (71xx) eBGP
neighbor 67.38.x.x password 7 1427414A1B110xxxxx
neighbor 67.38.x.x update-source FastEthernet0/1
neighbor 67.38.x.x version 4
neighbor 67.38.x.x send-community
neighbor 67.38.x.x soft-reconfiguration inbound
neighbor 67.38.x.x prefix-list Bronson-to-SBC out
neighbor 67.38.x.x route-map Bronson-to-SBC in
no auto-summary
ip prefix-list Bronson-Merit seq 5 permit 198.108.x.x/23
route-map Bronson-to-SBC permit 10
match ip address prefix-list Bronson-Merit
set local-preference 110
set community 467409418
Secondary router:
router bgp 40xxx
no synchronization
neighbor 198.108.x.x remote-as 2xx
neighbor 198.108.x.x description Bronson (40xxx) to Merit (2xx) eBGP
neighbor 198.108.x.x password 7 014312400B5D1xxxxx
neighbor 198.108.x.x update-source FastEthernet0/1
neighbor 198.108.x.x version 4
neighbor 198.108.x.x soft-reconfiguration inbound
neighbor 198.108.x.x prefix-list Bronson-Merit out
neighbor 198.108.x.x route-map MeritIn in
no auto-summary
route-map MeritIn permit 10
set local-preference 90
set as-path prepend 40xxx 40xxx 40xxx 40xxx 40xxx 40xxx
Not sure what else needs to be done. I have stressed myself out for the past few nights and its time to ask for a little help.
Thanks in advance.
Giuseppe Larosa Tue, 10/14/2008 - 08:36
  • Hall of Fame,
    Founding Member
Hello Chris,
you should do AS path prepend out to secondary ISP and not inbound:
should become:
neighbor 198.108.x.x route-map MeritIn out
this could help to minimize inbound traffic from secondary ISP but you cannot have a zero inbound from secondary ISP unless you use BGP conditional advertising (you advertise your networks to secondary ISP only if some BGP route coming from primary ISP is missing indicating primary eBGP session has failed)
Hope to help
Giuseppe
rais Tue, 10/14/2008 - 08:49
  • Silver, 250 points or more
Yes the problem is your as-path prepends as indicated by Giuseppe.
Thanks.
campbech1 Tue, 10/14/2008 - 09:23
Thanks guys. I have changed the line to read:
Do I need to issue any other commands for this to take effect?
Jon Marshall Tue, 10/14/2008 - 09:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
clear ip bgp 198.108.x.x soft out
Jon
