Backup on LMS
Oct 14th, 2008
I want to know if it is possible to install LMS single server installation for the purpose of backup.
Better still how do i perform backup for LMS installation for the purpose of disaster recovery.
Overall Rating: 0 (1 ratings)
David Stanford Wed, 10/15/2008 - 10:55
  • Cisco Employee,
LMS has its own backup utility built in. It's under Common Services - Serer - Admin - Backup
joachim_chan Tue, 03/06/2012 - 21:48
I have a question, is it possible to a server backup on LMS4.1? As in using symantec netbackup to backup OS and app.
Martin Ermel Wed, 03/07/2012 - 01:12
  • Blue, 1500 points or more
you can do a full backup (OS and apps) with LMS stopped and this backup can be used to do a full restore;
when you are using incremental backups with LMS running, exclude CSCOpx\databases from the backup as this data is useless for a restore (inconsistent databases). Instead, configure LMS to do scheduled backups - thus you have consistent databases and a definite state which you can be use for a restore of the LMS data. In this case you would first restore the OS and LMS and use the database backup created by LMS to restore LMS data.
