didyap Mon, 10/20/2008 - 07:02
You can use the Remove APs command in WCS to remove the configuration for the original lightweight access point. Keep in mind that only lightweight access points that are not currently registered with any WLAN controller can be removed from the WCS database via the Remove AP operation.
Following stetps may help you :
Step 1 Click Configure > Access Points to display the All Access Points page. In large networks, it is helpful to narrow the listing by using the "Search for APs By" filter in the left-hand margin.
Step 2 Select the non-registered access point(s) that you want to remove by enabling the appropriate check box(es).
Step 3 From the command drop-down menu in the right-hand upper corner of the screen, choose Remove APs and click GO.
Step 4 Confirm your intention to remove the lightweight access points. After doing so, the selected lightweight access point(s) are removed from WCS.
