10-14-2008 08:53 AM - edited 03-06-2019 01:55 AM
all,
can we force a router ethernet port to run at 100 meg? as far as i know this runs at 10 meg. can i configure it to 100 meg and duplex to full so that it communicate with a switch
Solved! Go to Solution.
10-14-2008 10:05 AM
As far as i know the 2610 has only 10baseT interface, so best you can get is 10full. The 2610XM model does support fast-ethernet.
Jon
10-14-2008 08:59 AM
John
Little confused by your question. If the port is fast ethernet yes you can configure as 100 full, but if just ethernet then it will only run at 10full.
What is the interface/router ?
Jon
10-14-2008 09:28 AM
hi jon, here's a show version of our router:
cisco 2610 (MPC860) processor (revision 0x202) with 61440K/4096K bytes of memory
Processor board ID JAB0314034T (1672352097)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
the ethernet interface will be connected to the LAN through a fastethernet port on a 2950G switch. my boss wants to run the connection at 100 meg. is this possible on ethernet port?
10-14-2008 10:05 AM
Jon
10-14-2008 10:38 AM
thanks jon!
