LMS 3.1 database
Oct 14th, 2008
LMS installation folder "CSCOpx" size is keep increasing in the Server hard drive. Please suggest how we can handle this situation to save C drive on the server (like using a different drive for LMS data in future /archiving the data)
Overall Rating: 4 (1 ratings)
Joe Clarke Tue, 10/14/2008 - 09:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You cannot keep data on one drive with the LMS application on another drive. If you need to migrate LMS from C to another drive, do an LMS data backup, then completely uninstall LMS from the server. Then, reinstall LMS onto the new drive. Patch LMS up to its previous level, then restore your backup.
gururajan Tue, 10/14/2008 - 09:26
Thanks for the reply.
How can we handle the situation when there is no free space in the LMS installed drive.
Should we keep migrating LMS completely to a new hardware?
Joe Clarke Tue, 10/14/2008 - 09:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
That is a reasonable consideration. However, if the server's resources are otherwise okay, you might just consider buying a new, bigger drive (or array) for the existing server.
