ASA 5505
Oct 14th, 2008
I would like to have a device on my network accessable from the outside world through ANY port
i have tried using the cmd lines below but with no luck...
access-list outside_access_in extended permit tcp any host 1.2.3.4
access-list outside_access_in extended permit tcp any host 1.2.3.4 eq any
anyone have any ideas?
Jon Marshall Tue, 10/14/2008 - 09:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Have you setup Nat for this host ? eg.
static (inside,outside)
Jon
suschoud Tue, 10/14/2008 - 12:46
  • Gold, 750 points or more
is the " access-g outside_access_in in interface outside " in place ?
Sushil
suschoud Tue, 10/14/2008 - 13:07
an access list is of no use till the time it is applied on an interface.
through " access-group " command we apply an access list on an interface.
PLease add the command from my previous post...should work.
Do rate helpful posts.
Sushil
JORGE RODRIGUEZ Tue, 10/14/2008 - 13:18
  • Green, 3000 points or more
In addition to placing the access-group couple of things you may want to check in the event that you already have access-group outside_access_in in interface outside statement in firewall and still no connection.
1-Make sure the server does not have any firewall of its own enable
2- Make sure the server does indeed listen on ports intended, example lets say port 80 for web, or SSL, telnet, ftp etc..
3- do a telnet test towards the server pub ip from an outside host if you can on the ports the server is listening on.
c:\telnet
look at the logs on asdm see what it tells you while you try connection from the outside.
Rgds
Jorge
