jsivulka Mon, 10/20/2008 - 07:05
  • Bronze, 100 points or more
Could you generate, a new licence file with functional licence (i think - with a name "SevidorWCS" only). I think it is
incompatibility between Cisco names and MS-Windows names of host.
scottwilliamson Mon, 10/27/2008 - 03:27
I had a similar sounding problem and it was down to an error on my part - when I registered the license on the website I entered "servername" but when I built the server using the install discs I entered "servername.ourcompany.co.uk" and of course the server names didn't match. I spoke to our vendor who got in touch with Cisco who supplied a license file wiith the correct name.
Hope this helps,
Scott
dennischolmes Wed, 10/29/2008 - 07:39
  • Gold, 750 points or more
Do not use the fully qualified domain host name on your server and then ask for the simple host name on the license. It is a common mistake. The two must match identically.
Pushkar Sambhoos Mon, 12/08/2008 - 23:34
  • Cisco Employee,
Hostname is not case sensitive. Please issue the command 'hostname' on your WCS server. The output of this command needs to exactly match the one in the license file. If it doesn't you need to get your license rehosted. Please open a Cisco TAC case for this.
Trending Topics - Security & Network
