Having issues with VLAN on 3548 switch. Please help
Oct 14th, 2008
I am running a VLAN on a switch it runs fine until I plug a certain machine into it I get the following erorr:
2y43w: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/42 (10), with sw-2 FastEthernet0/45 (1).
Interface 45 is the one causing the issue. When I put interface 45 on the VLAN it is supposed to be which is VLAN10 it freezes up our network and starts relearning addresses
2y43w: %RTD-1-ADDR_FLAP: FastEthernet0/45 relearning 6 addrs per min
Any ideas?
Let me know if you need more info.
Thanks!
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 10/14/2008 - 10:19
  • Hall of Fame,
    Founding Member
Hello Justin,
you have a Native Vlan mismatch:
the two sides don't agree on the native vlan number that is the vlan whose frames are sent out the 802.1Q trunk untagged = as normal ethernet frames with no vlan tag in them
verify by comparing config
sw1# sh run int f0/42
compare with
sw2# sh run int f0/45
the first one has a line
switchport trunk native vlan 10
that is missing on the second (vlan 1 native is default )
fix this mismatch or you can have IP connectivity problems because each switch thinks untagged frames belong to a different broadcast domain
Hope to help
Giuseppe
j.zortman Tue, 10/14/2008 - 12:00
Thanks for the reply!
Right it does. However the problem is, that both 42 and 45 should be in VLAN 10. When I try to add 45 to VLAN I get some sort of loop where all the lights flash like crazy on the switch and I get the following message:
It basically shuts down a part of our network when this happens.
Giuseppe Larosa Tue, 10/14/2008 - 12:15
  • Hall of Fame,
    Founding Member
Hello Justin,
you need to hardcode they are access ports
sw1 # int f0/42
switchport
switchport mode access
switchport access vlan 10
the same on other side
they can be trying to negotiate a trunk dynamically and so then you have unexpected behaviuor
Hope to help
Giuseppe
j.zortman Tue, 10/14/2008 - 12:17
Giuseppe, I have them both setup that way.
Thanks.
glen.grant Tue, 10/14/2008 - 16:06
  • Purple, 4500 points or more
It looks like you have a physical wiring loop from one f0/42 to f0/45 and you will have to figure out where that is . If you have portfast on the ports turn it off temporarily while you plug those ports in and see if spanning tree will put one of the ports into blocking mode . Probably someone has one of those nice little home switches at their desk and has managed to loop the wiring going back to the switch , see it all the time .
Giuseppe Larosa Tue, 10/14/2008 - 21:44
  • Hall of Fame,
    Founding Member
Hello Glen,
you're right they see each other CDP messages
Best Regards
Giuseppe
j.zortman Wed, 10/15/2008 - 06:58
Thanks Glen.
Both ports 42 and 45 are servers and there is nothing but servers on this switch.
What should I try?
Thanks!
glen.grant Wed, 10/15/2008 - 12:12
I would trace out the wiring on 42 and 45 and see where they go . Someone may have done some creative networking that you don't know about .
j.zortman Wed, 10/15/2008 - 12:21
They both go to the servers.
Now would this make a difference, these are 2 servers that have 2 other virtual machines on them and those have virtual interfaces.
j.zortman Thu, 10/16/2008 - 09:02
Hmm So I unplugged fa0/42 and put fa0/45 and I dont get the errors. So there is something between those 2 machines that they dont like and it creates some sort of loop.
Is there a way to test and get to the bottom of this?
Thanks.
j.zortman Thu, 10/16/2008 - 09:54
I turned debug ethernet-controller address on and I gte the following messages...any ideas?
2y43w: Add address 0016.32, on port Fa0/42 vlan 10
2y43w: Add address 0016.32, on port Fa0/45 vlan 1
2y43w: Delete address 0019.b, on port Fa0/42 vlan 10
2y43w: Add address 0014.fd, on port Fa0/45 vlan 1
2y43w: Add address 0006.5a, on port Fa0/45 vlan 1
2y43w: Add address 0006.5a, on port Fa0/42 vlan 10
2y43w: Add address 000d.3, on port Fa0/45 vlan 1
2y43w: Add address 000d., on port Fa0/42 vlan 10
Giuseppe Larosa Thu, 10/16/2008 - 13:20
  • Hall of Fame,
    Founding Member
Hello Justin,
I think the servers are bridging to each other and CDP messages are L2 multicast so they pass through.
You should verify the networking config of the servers both physical and virtual instances.
Hope to help
Giuseppe
j.zortman Thu, 10/16/2008 - 13:32
Yes I think it is something with the servers as well. We are running Zend Core on there with it having 2 other virtual machines on it.
Just cant seem to figure out where the issue is on the interfaces.
Giuseppe Larosa Thu, 10/16/2008 - 14:29
  • Hall of Fame,
    Founding Member
Hello Justin,
the servers have at least another NIC each of them and they are bridging between external NIC and internal NIC and then the second from internal NIC to external NIC
where I called external NICs the ones that are cabled to your switches' ports.
on www.cisco.com/go/srnd there is a design guide for VMware.
However, if there are "servers" people I would involve them in this issue: explain them that the two servers are disturbing the infrastructure networking and you should disable the ports for the network safety ...
Hope to help
Giuseppe
j.zortman Fri, 10/17/2008 - 08:40
OK here is another weird part about it. Both servers have to NIC cards. On both NIC card 1 is plugged into a 207 network on a dell switch and it works fine with no messages. NIC card 2 on both is plugged into a 172 network cisco 3548 and thats where I am getting the errors.
Just seems strange that it is happening on 1 switch but not the other.
Any thoughts on that?
Thanks!
