How to get CSS from an extension
Answered Question
Oct 14th, 2008
I just need to use AXL to get the css config in the specific extension .. I check the AXL GetLine but somehow i can not found it ...
what i can think is maybe ExceuteSQL but i am no idea to start from... I appreciated if guru here provide example of ExceuteSQL Query ...
Thanks.
natta
Correct Answer by Sascha Monteiro about 8 years 8 months ago
ok,
just out the top of my head, just to make the point;
select numplan.dnorpattern,callingsearchspace.name from numplan join callingsearchspace on (callingsearchspace.pkid = numplan.fkcallingsearchspace_sharedlineappear
) where numplan.dnorpattern = '1234'
but if you use getLine, you need to use
and then do a getCSS with that uuid
hth
Sascha
Overall Rating: 5 (1 ratings)
Correct Answer
Sascha Monteiro Tue, 10/14/2008 - 18:16
  • Silver, 250 points or more
ok,
hth
Sascha
