Wireless EAP / 802.1x with MS NAP
Oct 14th, 2008
I'm trying to configure 802.1x on a 1131AG AP using MS NAP as a radius server.
Using a switch everything works fine with EAPOL and the clients authenticate the way they should. But as soon as I start using the AP and clients try to authenticate, the AP shows "failed to authenticate" + clients MAC address.
I've attached both configs:
The switch config, on which Fa0/6 is used to authenticate a connected client, and the AP config which doesnt work and probably has something missing.
The clients should authenticate against the radius server 10.10.250.111 and, according their health status, put in vlan 1 (healty) or vlan 2 (unhealthy).
I would like to use WPA2 as an encryption method.
Trending Topics - Security & Network
