Enable or disable Secure Desktop based on Client/Clientless
Answered Question
Oct 14th, 2008
Is it possible to enable Secure Desktop for clientless connections while disabling it for AnyConnect client connections?
Correct Answer by Nelson Rodrigues about 8 years 6 months ago
Capability to enable/disable CSD per tunnel group(TG)/Connection Profile will come in future image.
Then you should be able to set one TG for Clientless with/withour CSD; and anher TG for AnyConnect/Client with/without TG.
Nelson
Overall Rating: 5 (1 ratings)
c.hulcher Mon, 10/20/2008 - 05:18
Yes, only thing is the criteria I want to match is Clientless vs. Client based which isn't currently available.
Correct Answer
Nelson Rodrigues Sun, 10/19/2008 - 05:53
  • Cisco Employee,
Nelson
c.hulcher Mon, 10/20/2008 - 05:16
Do you have a timeframe for when this feature might be added?
