10-14-2008 02:57 PM
Does anyone know whether the boot up POST messages are kept somewhere on the devices itself? For instance debug messages are kept in local log buffer (show log) but I have no idea whether the POST messages are kept or not. Thanks for your feedback.
Solved! Go to Solution.
10-14-2008 05:09 PM
This won't work for routers. It does work for desktop switches running 12.2(25)SEE and higher. The 2950s cannot run that code, but do offer a "show post" command.
10-14-2008 04:50 PM
Depends on the device type, but "show diagnostic post" should work on the desktop switches.
10-14-2008 05:06 PM
Thanks for the reply. I found that this must be some kind newer OS for this command but I found no trace of it on Cat2950 (IOS 12.1.14), Cat3750 (IOS 12.2.25), Cisco 2811 (IOS 12.4.9) and those are the kind of devices I have in my network. the closest is on the cisco 2811 router that shows:
CarzoSYD01c2801#sho diag?
diag
Router#sho diag
Router#sho diag ?
<0-0> Slot number
| Output modifiers
Router#sho diag
10-14-2008 05:09 PM
