AP-1121G do not even try to join to WLC-1206
Scott Fella Wed, 10/15/2008 - 05:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Did you add the SSC to the WLC after you did the upgrade?
Rob Huffman Sat, 11/01/2008 - 09:29
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Dmitry,
I have worked with some other NetPros where this happened (no SSC created) they had to downgrade the AP to Autonomous and run the upgrade to LWAPP over again. Then it worked properly;
Using a TFTP Server to Return to a Previous Release
Note This section does not apply to Cisco C3201WMIC and Cisco C3201LAP.
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 On the PC where the TFTP server is located, perform these steps:
a. Disable any software firewall products, such as Windows firewall, ZoneAlarm firewall, McAffee firewall, or others.
b. Ensure all Windows files are visible. From Windows Explorer, click Tools > Folder Options > View > Show hidden files and folders.
Step 4 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, c1240-k9w7-tar.default for a 1240 series access point, and c1250-k9w7-tar.default for a 1250 series access point.
Step 5 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 6 Disconnect power from the access point.
Step 7 Press and hold MODE while you reconnect power to the access point.
Step 8 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 9 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 10 After the access point reboots, reconfigure it using the GUI or the CLI.
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
Hope this helps!
Rob
wesleyterry Sun, 01/18/2009 - 21:02
  • Bronze, 100 points or more
can you post the logs of the AP when it tries to join.
You mentioned the join request, but it would be nice to see all of the entries.
Furthermore, you should be able to debug on the WLC to see what it says about this AP. Maybe debug the MAC of the AP will show you something?
Better yet, are any of your APs working or is it just this one that doesn't join?
What Version of WLC?
Hello!
Could you tell me how can I get logs from AP?
Well, I tried this- I don't see join request from AP.
There are no working APs, I'm trying to add one AP (of 2 I have) to controller
I tried several, now it is 4.2.
wesleyterry Sun, 01/18/2009 - 21:31
If you physically console into the AP (is that available on an 1121?) and I think password is like "Cisco" on most APs, you should be able to see the log. I don't have access to an AP right now but I think there should be some kind of debug command accessible from the console to indicate the LWAPP events...
Is the controller and AP in the same VLAN/Subnet? Same switch? Is it the same VLAN/Subnet as other working devices?
Could you post the run-config of your WLC?
unfortunately, there is no serial console on 1121 :-(
They are in the same subnet, and I tried to connect them using one switch.
(Cisco Controller) >show running-config
802.11a cac voice tspec-inactivity-timeout ignore
802.11a cac voice stream-size 84000 max-streams 2
802.11b cac voice tspec-inactivity-timeout ignore
802.11b cac voice stream-size 84000 max-streams 2
aaa auth mgmt local radius
advanced 802.11a channel add 100
advanced 802.11a channel add 104
advanced 802.11a channel add 108
advanced 802.11a channel add 112
advanced 802.11a channel add 116
advanced 802.11a channel add 120
--More-- or (q)uit
advanced 802.11a channel add 124
advanced 802.11a channel add 128
advanced 802.11a channel add 132
advanced 802.11a channel add 136
advanced 802.11a channel add 140
advanced 802.11a channel add 149
advanced 802.11a channel add 153
advanced 802.11a channel add 157
advanced 802.11a channel add 161
advanced 802.11a receiver pico-cell-V2 rx_sense_thrld 0 0 0
advanced 802.11a receiver pico-cell-V2 cca_sense_thrld 0 0 0
advanced 802.11a receiver pico-cell-V2 sta_tx_pwr 0 0 0
--More-- or (q)uit
advanced 802.11b tx-power-control-thresh -65
Location Summary
Algorithm used: Average
Client
RSSI expiry timeout: 5 sec
Half life: 0 sec
Notify Threshold: 0 db
Calibrating Client
Half life: 0 sec
Rogue AP
Half life: 0 sec
RFID Tag
Half life: 0 sec
--More-- or (q)uit
location rssi-half-life tags 0
location rssi-half-life client 0
location rssi-half-life rogue-aps 0
location expiry tags 5
location expiry client 5
location expiry calibrating-client 5
location expiry rogue-aps 5
Cisco Public Safety is not allowed to set in this domain
ap syslog host global 255.255.255.255
auth-list ap-policy ssc enable
auth-list add mic 00:21:55:74:af:82
country RU
--More-- or (q)uit
dhcp proxy disable
local-auth method fast server-key *****
interface address ap-manager 192.168.22.19 255.255.255.0 192.168.22.221
interface address management 192.168.22.18 255.255.255.0 192.168.22.221
interface address virtual 1.1.1.1
interface dhcp ap-manager primary 192.168.22.220
interface dhcp management primary 192.168.22.220
interface port ap-manager 2
interface port management 1
load-balancing window 5
logging buffered 7
--More-- or (q)uit
logging console 7
memory monitor error disable
memory monitor leak thresholds 10000 30000
mesh security eap
mgmtuser add cisco **** read-write
mobility group domain Belkam
network webmode enable
network telnet enable
network multicast mode multicast 0.0.0.0
network mgmt-via-dynamic-interface enable
network otap-mode disable
network rf-network-name Belkam
--More-- or (q)uit
snmp version v2c enable
snmp version v3 enable
sysname WLC2106
time ntp interval 28800
time ntp server 1 192.168.22.99
trapflags 802.11-Security ids-sig-attack disable
802.11a disable network
btw, this is what I get on controller with
debug lwapp events enable
Mon Jan 19 09:42:22 2009: 00:21:55:74:af:82 Received LWAPP DISCOVERY REQUEST from AP 00:21:55:74:af:82 to ff:ff:ff:ff:ff:ff on port '1'
Mon Jan 19 09:42:22 2009: 00:21:55:74:af:82 Successful transmission of LWAPP Discovery Response to AP 00:21:55:74:af:82 on port 1
Mon Jan 19 09:42:22 2009: 00:21:55:74:af:82 Received LWAPP DISCOVERY REQUEST from AP 00:21:55:74:af:82 to ff:ff:ff:ff:ff:ff on port '2'
Mon Jan 19 09:42:22 2009: 00:21:55:74:af:82 Successful transmission of LWAPP Discovery Response to AP 00:21:55:74:af:82 on port 2
Leo Laohoo Sun, 01/18/2009 - 21:56
  • Hall of Fame,
    2017 LAN, Wireless
Can LAP1121 ping the Management IP Address of the 2106?
If yes, then try the following command on the LAP1121:
lwapp ap controller ip address
Does this help?
Leo Laohoo Mon, 01/19/2009 - 13:01
  • Hall of Fame,
    2017 LAN, Wireless
Yes. Console to the LAP1121 and verify if you can ping the Management Interface IP Address or not. If YES, then type the command from the LAP1121:
Does this help?
I can ping from 1121 with IOS (not LWAPP!)
ap#ping 192.168.22.18
Sending 5, 100-byte ICMP Echos to 192.168.22.18, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/3 ms
but there is no such command:
ap#conf t
Enter configuration commands, one per line. End with CNTL/Z.
ap(config)#lwapp ap controller ip address 192.168.22.18
% Invalid input detected at '^' marker.
ap(config)#exit
ap#lwapp ap controller ip address 192.168.22.18
Scott Fella Tue, 01/20/2009 - 05:18
  • Hall of Fame,
    2017 Wireless
Just for kicks... can you place the ap-manager in port 1 instead of port 2 and see if the ap joins. If so, then you have an issues with your switch port configuration.
Also, can you post the switch port configuration of the ports the wlc is connected to.
