CCM3.3 - Not able to make any changes
Oct 14th, 2008
Running CCM 3.3(3)sr4a.
Past some days facing a problem like not able to make any changes.Whenever we make changes and try to update we will get following error:
"A com error occurred during processing (6)
Details:-Error No:-2147219962(0x80040606) CDBLException Dump [com Error]"
Note:Currently CCM server doesn't have any password(it's blank).
Please help me out to resolve the issue.
tim.giles Wed, 10/15/2008 - 01:40
Usually COM errors can be fixed by re-starting the relevant COM services. Are all the CCM services started (how about the Windows ones as well)?
Try the following and see if it helps:
In the Cisco CallManager server, choose Start > Programs > Administrative Tools > Component Services.
Click on the plus by Component Services.
Click on the plus by Computers.
Click on the plus by My Computer.
Click on the plus by COM+ Applications.
Right-click on DBL and choose Shutdown.
Right-click on DBL and choose Start.
Open a DOS window and type iisreset, then check if IIS admin and WWW services are in the started state.
Please rate useful posts..
Jaime Valencia Wed, 10/15/2008 - 05:29
check pwd sync with adminutility, maybe reset the pwd, and also restart the server
java
if this helps, please rate
