10-14-2008 09:42 PM
Hi gurus,
will there any problem if i used GBIC to SFP with a short distance around 10m usign an LX type for both? What would be the implications on using different types on different distances?
tnx.
10-18-2008 02:00 AM
Hello Jefferson,
I think you can do it use single mode fiber
Hope to help
Giuseppe
10-18-2008 09:16 PM
Hi Giuseppe,
I was just concern on the distance and the power, since it should be use on long distances yet i will use it on short distance.
Thanks.
10-20-2008 02:03 AM
Hello Jefferson,
I used this setup with only few meters of fiber in lab setup and it worked well.
Sometimes you may need to insert a 5dB /10dB attenuator all depends on the power budget.
Hope to hope
Giuseppe
