6500 fabric switching mode question
Oct 14th, 2008
I confused about explanation of fabric switching mode of 6500 on CCO, like below
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/swfab.html
CCO said Dbus header is transmited on switching fabirc channel, but DBUS located on share BUS, why DBUS header transmited on switching fabirc channel.
thank you!
Jun
Compact mode-The switch uses this mode for all traffic when only fabric-enabled modules are
installed. In this mode, a compact version of the DBus header is forwarded over the switch fabric
channel, which provides the best possible performance.
Truncated mode-The switch uses this mode for traffic between fabric-enabled modules when there
are both fabric-enabled and nonfabric-enabled modules installed. In this mode, the switch sends a
truncated version of the traffic (the first 64 bytes of the frame) over the switch fabric channel.
Bus mode (also called flow-through mode)-The switch uses this mode for traffic between
nonfabric-enabled modules and for traffic between a nonfabric-enabled module and a fabric-enabled
module. In this mode, all traffic passes between the local bus and the supervisor engine bus.
