Why the ACS block my Console Login?
Answered Question
Oct 14th, 2008
I have aaa to my SWs an ROuters, but wen my Server goes down I cant get access ont the console port.
My config is attached and the debug aaa authorization.
this are the debugs for each acces: Telnet tacacs user, consoler tacacs user and the try whit the local user.
telnet access
Oct 15 01:03:09: AAA: parse name=tty2 idb type=-1 tty=-1
Oct 15 01:03:09: AAA: name=tty2 flags=0x11 type=5 shelf=0 slot=0 adapter=0 port=2 channel=0
Oct 15 01:03:09: AAA/MEMORY: create_user (0x2778E84) user='NULL' ruser='NULL' ds0=0 port='tty2' rem_addr='10.10.10.23' authen_type=ASCII service=LOGIN priv=1 initial_task_id='0', vrf= (id=0)
Oct 15 01:03:10: %CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on GigabitEthernet0/37 (102), with tst1-s2 GigabitEthernet0/1 (1).
Oct 15 01:03:11: AAA/MEMORY: free_user (0x28E1BFC) user='ACS-USER' ruser='NULL' port='tty2' rem_addr='10.10.10.23' authen_type=ASCII service=ENABLE priv=15
Oct 15 01:03:13: AAA/MEMORY: free_user (0x2778E84) user='ACS-USER' ruser='NULL' port='tty2' rem_addr='10.10.10.23' authen_type=ASCII service=LOGIN priv=1
COnsole access (Working whit the ACS user)
Oct 15 01:08:57: AAA: parse name=tty0 idb type=-1 tty=-1
Oct 15 01:08:57: AAA: name=tty0 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=0 channel=0
Oct 15 01:08:57: AAA/MEMORY: create_user (0x28AA8E4) user='NULL' ruser='NULL' ds0=0 port='tty0' rem_addr='async' authen_type=ASCII service=LOGIN priv=1 initial_task_id='0', vrf= (id=0)
Oct 15 01:09:11: AAA/MEMORY: free_user (0x27C0DC4) user='ACS-USER' ruser='NULL' port='tty0' rem_addr='async' authen_type=ASCII service=ENABLE priv=15
Oct 15 01:09:18: AAA/MEMORY: free_user (0x28AA8E4) user='ACS-USER' ruser='NULL' port='tty0' rem_addr='async' authen_type=ASCII service=LOGIN priv=1
console access (Not working whit the local user)
Oct 15 01:05:24: AAA: parse name=tty0 idb type=-1 tty=-1
Oct 15 01:05:24: AAA: name=tty0 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=0 channel=0
Oct 15 01:05:24: AAA/MEMORY: create_user (0x27C1310) user='NULL' ruser='NULL' ds0=0 port='tty0' rem_addr='async' authen_type=ASCII service=LOGIN priv=1 initial_task_id='0', vrf= (id=0)
Oct 15 01:05:36: AAA/MEMORY: free_user_quiet (0x27C1310) user='LOCAL_USER' ruser='NULL' port='tty0' rem_addr='async' authen_type=1 service=1 priv=1
Oct 15 01:05:36: AAA: parse name=tty0 idb type=-1 tty=-1
Oct 15 01:05:36: AAA: name=tty0 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=0 channel=0
Oct 15 01:05:36: AAA/MEMORY: create_user (0x28D201C) user='NULL' ruser='NULL' ds0=0 port='tty0' rem_addr='async' authen_type=ASCII service=LOGIN priv=1 initial_task_id='0', vrf= (id=0)
Oct 15 01:06:09: AAA/MEMORY: free_user_quiet (0x28D201C) user='NULL' ruser='NULL' port='tty0' rem_addr='async' authen_type=1 service=1 priv=1
Oct 15 01:06:09: AAA: parse name=tty0 idb type=-1 tty=-1
Oct 15 01:06:09: AAA: name=tty0 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=0 channel=0
Oct 15 01:06:09: AAA/MEMORY: create_user (0x2773004) user='NULL' ruser='NULL' ds0=0 port='tty0' rem_addr='async' authen_type=ASCII service=LOGIN priv=1 initial_task_id='0', vrf= (id=0)
Oct 15 01:06:41: AAA/MEMORY: free_user (0x2773004) user='NULL' ruser='NULL' port='tty0' rem_addr='async' authen_type=ASCII service=LOGIN priv=1
Thanks for your help.
Correct Answer by Premdeep Banga about 8 years 9 months ago
Change your commands from,
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+
To,
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
Prem
Please if it helps!
Overall Rating: 5 (1 ratings)
Correct Answer
Premdeep Banga Wed, 10/15/2008 - 03:36
  • Gold, 750 points or more
To,
Prem
Please if it helps!
