what different between 6500 and 7600
Oct 15th, 2008
i haven't seen any different.
thank you
Marwan ALshawi Wed, 10/15/2008 - 01:59
the main diffrence is 6500 is switch 7600 is router
siwtch has switching capabilities in addition to routing prossecing
Jon Marshall Wed, 10/15/2008 - 02:44
The 6500 and the 7600 can run many of the same moddules. They are both capable of L2 & L3 switching. They used to share the same code base but they now have different code bases.
Basically the 7600 is more focused towards WAN and the 6500 is more focused on LAN. Certain cards will only be supported in one of the chassis eg. certain WAN cards are only available on 7600.
So you pick the one you want depending on it's intended use.
