10-15-2008 12:19 AM - edited 03-11-2019 06:57 AM
I have two PIX firewall(6.3) configured in failover (LAN failover)mode,now I want to disable the failover and willing to use the PIX firewalls in stand alone mode at two different site.
Is it possible?How to do that?I hope by simply disabling the LAN failover we can use the PIX firewall in stand alone mode Is in it?
Thanks and Regards,
S.Venkataraman
10-15-2008 12:40 AM
It depends what license is on you failover unit , you can check it with
show version
If its failover you cannot use it as standalone.. you need upgrade it to restricted or to unrestricted license
M.
Hope that helps rate if it does
10-16-2008 02:03 AM
Dear M.Sir,
One of the firewall is having 100 user license and the other one is Fail Over license.How I can use both firewall as the stand alone firewall.What is the procedure?
Please guide me.
Thanks and Regards,
S.Venkataraman.
10-16-2008 02:05 AM
You need buy at least restricted license after you receive activation key
check this
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00806b1c0f.shtml
M.
10-16-2008 04:31 AM
Hi M.Sir,
The following is the Active Firewall.
Cisco PIX Firewall Version 6.3(5)
Cisco PIX Device Manager Version 3.0(4)
Compiled on Thu 04-Aug-05 21:40 by morlee
MRFHOFIRE up 1 day 22 hours
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: ethernet0: address is 0017.9514.8726, irq 10
1: ethernet1: address is 0017.9514.8727, irq 11
2: ethernet2: address is 000d.8811.d8d0, irq 11
3: ethernet3: address is 000d.8811.d8d1, irq 10
4: ethernet4: address is 000d.8811.d8d2, irq 9
5: ethernet5: address is 000d.8811.d8d3, irq 5
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 6
<--- More --->
Maximum Interfaces: 10
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
Running Activation Key: 0x08837644 0x7deb2bea 0xfd77c81c 0xda67cef7
Configuration last modified by enable_15 at 17:19:56.818 IST Tue Oct 14 2008
The the following is the Fail Over firewall.
pixfirewall up 46 mins 27 secs
0: ethernet0: address is 0017.9514.8728, irq 10
1: ethernet1: address is 0017.9514.8729, irq 11
2: ethernet2: address is 000d.8811.cec4, irq 11
3: ethernet3: address is 000d.8811.cec5, irq 10
4: ethernet4: address is 000d.8811.cec6, irq 9
5: ethernet5: address is 000d.8811.cec7, irq 5
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
Guards: Enabled
This PIX has a Failover Only (FO) license.
Running Activation Key: 0xa0b73dbd 0xe6f0009e 0xacc43ad4 0x269ec60c
Configuration last modified by enable_15 at 12:07:08.309 UTC Mon Oct 13 2008
I need to buy license for both firewall or only for the Fail Over firewall.
Please help me.
Thanks and Regards,
S.Venkataraman.
