copy ios on compact flash
Oct 15th, 2008
hi,
i have 3845 router i have download a new ios and want to copy that ios on compact flash. how can i do that.
itdsmartnet Wed, 10/15/2008 - 02:32
hi,
i have already checked the above link. how should i know that compact flash is working, and which command do i need to issue in order to copy ios from tftp to compact flash.
My compact flash is inserted into router already. but when i issue command sh flash: the output is as follow:Directory of flash:/
1 -rw- 16345060 Feb 01 2008 21:04:08 +00:00 c3845-ipbase-mz.124-3i.bin
2 -rw- 1826 Feb 01 2008 21:12:00 +00:00 sdmconfig-38xx.cfg
3 -rw- 6036480 Feb 01 2008 21:12:30 +00:00 sdm.tar
4 -rw- 861696 Feb 01 2008 21:12:48 +00:00 es.tar
5 -rw- 1164288 Feb 01 2008 21:13:06 +00:00 common.tar
6 -rw- 1038 Feb 01 2008 21:13:20 +00:00 home.shtml
7 -rw- 113152 Feb 01 2008 21:13:32 +00:00 home.tar
8 -rw- 1697952 Feb 01 2008 21:13:52 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
9 -rw- 416354 Feb 01 2008 21:14:08 +00:00 sslclient-win-1.1.3.173.pkg
is it internal flash output or compact flash output?
Joseph W. Doherty Wed, 10/15/2008 - 04:25
Likely your directory is of internal flash.
There's an option to the directory command to show all. (Something like /allfilesystem - I'm not at a Cisco router to check syntax.)
If you're using "brand X" compact flash, it might not be recognized by the router. You also might need for format within the router.
itdsmartnet Wed, 10/15/2008 - 04:57
thanks for your reply, the following is the output of show file system:
sh file systems
File Systems:
Size(b) Free(b) Type Flags Prefixes
- - opaque rw archive:
- - opaque rw system:
491512 482579 nvram rw nvram:
- - opaque rw null:
- - network rw tftp:
* 63995904 32714752 disk rw flash:#
- - opaque ro xmodem:
- - opaque ro ymodem:
- - network rw rcp:
- - network rw pram:
- - network rw ftp:
- - network rw http:
- - network rw scp:
- - network rw https:
- - opaque ro cns:
how do i format compact flash card.
is66rlhntadm Wed, 10/15/2008 - 06:02
if your talking about the CF card on the front of the router try sh slot0:
the CF on the Main-board is Flash: the one on the front (I know some think of it as the back) is Slot0:
itdsmartnet Wed, 10/15/2008 - 20:59
hi,
The "show slot 0 " commnad is not available. how should i access that compact flash. My version is 3800 Software (C3845-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2).
Jon Marshall Thu, 10/16/2008 - 06:18
Try doing
dir /all
and see what it comes back with. Also try
dir slot0:
dir disk0:
Jon
is66rlhntadm Thu, 10/16/2008 - 13:23
try
sh s?
its "sh slot0:"
no space between the t and the zero
and its possible that you need the colon
you might try looking over "Show file systems" this will list all file systems on the router
