Route map
Oct 15th, 2008
Guys as far as i knoiw we have to use match and set command in router map......i was looking a config on a router and there was no set command on the route map......
route map XXX permit 10
match interface f0/1
why there is no set ccommand can route map work without set command.....thanks
francisco_1 Wed, 10/15/2008 - 02:57
  • Gold, 750 points or more
you should have the set command under the route-map.
post the show version on your router.
Francisco
