Creating DMP template in Dreamweaver
Oct 15th, 2008
Hi, I'm trying to set up a template in Dreamweaver to play on several DMP's. All the elements work on playback apart from the video. The same video works when I run it via the digital media designer but I don't like using that.
Can anyone help
smahbub Tue, 10/21/2008 - 08:10
  • Silver, 250 points or more
The DMP browser can work with files of these types, but not with files of any other type:
1)HTML
2) TXT
3) GIF
4) JPEG
5) PNG
6) SWF (Flash 6 or Flash 7)
You cannot install browser plug-ins or any other software on your DMP, whether to support additional file types or for any other purpose. No Java Runtime Environment (JRE) is installed.
