CCM 6.0 Directory
Oct 15th, 2008
Hii,,
Is there is any chance to change the directory setting in call manger 6 to display the first name then the las name.
It was easy in ccm 4.2 cox it was windows based, but now how can I access the file.
Overall Rating: 3 (1 ratings)
Jaime Valencia Wed, 10/15/2008 - 05:34
  • Cisco Employee,
  • Hall of Fame,
    2011
can't do now, changes like that require a separate server on which to place the directory script phones look at. same as idle url, you need a separate web server on which to place the file since you can't access the files on the server
java
if this helps, please rate
