Recieving fast busy tone on 6.x version
Oct 15th, 2008
Hi Team
we are facing an issue in whic we are recieving fast bust tone Intermittently on going through PSTN and on internal extensions as well.
Vaibhav
Jaime Valencia Wed, 10/15/2008 - 05:32
  • Cisco Employee,
  • Hall of Fame,
    2011
you need CUCM traces and debugs on the GW to find out the cause of that, you provide too little information to tell what could be the issue
java
if this helps, please rate
vaibhav-g Thu, 10/16/2008 - 02:55
Hi Java
plse find the attached show tech for the router.
plse try to find out the root cause for this
any suggestion,what can be the possible reasons for this.
Vaibhav
Jaime Valencia Thu, 10/16/2008 - 06:24
  • Cisco Employee,
  • Hall of Fame,
    2011
sh tech won't do anything on this case
you need to review CUCM traces and possibly a debug isdn q931 and/or debug voip ccapi inout to find the cause of this.
gather and review the traces, if you do not have the knowledge on how to read them i'd recommend you to open a TAC case so a CSE can determine the cause of this
java
