keepalive uri for Directory and not file extension - CSS
Oct 15th, 2008
Hi all,
I'm trying to define the keepalive uri for 1 service, based on the following criteria:
url:
1 - example.domain.com/forum
service esl0001-8878
ip address 10.1.1.1
port 8878
keepalive type http
keepalive port 8878
keepalive uri "/forum"
active
I've only found working examples with the uri sample, like "index.html", and other with extensions...
...none, with a directory in the url.
Best Regards,
Petrónio
Overall Rating: 5 (1 ratings)
Gilles Dufour Thu, 10/16/2008 - 03:54
The CSS will just used whatever string you configure to build the GET request.
If you want to configure a directory, it should work.
Gilles.
b.petronio Sat, 10/18/2008 - 13:25
Tks for answer it Gilles,
As i remember, the "show service" for that keepalive type, shows a down service.
It's well configured ?, the keepalive string i gave in the config ?
Tks for your effort,
Best Regards,
Petrónio
Gilles Dufour Mon, 10/20/2008 - 05:37
The config is ok.
But you may have to do "/forum/" as my server sends a 301 redirect when doing just "/forum".
The CSS expects a 200 ok and would consider the server down if receiving any other response.
Gilles.
b.petronio Mon, 10/20/2008 - 06:02
Thank you Gilles,
I already try it like u say... but it never comes up...
You are right once again, i saw it in the httpwatch, the redirect to /forum/, but as the content filter for a domain, we use url "//*.example.com", we could use some other thing in here, not related to the string only.
I already try changing the method from head to get, cause i read somewhere it could be the reason for not going up... no positive result.
I think i will try to convence the systems guys to apply a dummy file, like something.html .
b.petronio Mon, 10/20/2008 - 06:11
Sorry for bothering you, but i realize that im only receiving a 302 redirect, for another url related for a SSO, (Single Sign On).
I try to configure the "keepalive http-rspcode 302" command, but not even that it seems to put the service up.
If i just put uri "/", it comes up.
Thanks once again.
Petrónio
