CIFS with WEB Portal
Oct 15th, 2008
I have a problem when I'm connected via WebVpn Portal on my ASA 8.0(2) to access to my shared folder.
If i use with my cisco vpn client install on my computer i can access to my shared folder.
Have you ever meet this problem?
bwilmoth Tue, 10/21/2008 - 10:39
  • Silver, 250 points or more
The clientless version of webvpn doesnot support sharing of files and folders. you need to use the any connect vpN client and configure the ASA for the Anyconnect vpn client.
ldesmasures Wed, 10/22/2008 - 00:07
I think your wrong.
I've already configured CIFS shared access on ASA 8.0(1) (without Anyconnect) like a resource on Webportal and it's working !
And it was working with SSO on an active directory. The authentication used for the webportal was used for the CIFS share.
The only problem I encountered was a bug (CIFS doesn't work after a certain time) which is fixed in 8.0(3) or 8.0(4).
