Urgent Pls Help - Debug Ethernet Interface on ASA
Oct 15th, 2008
Hi, is there command to debug an Interface on an ASA5510 (7.2) ?
We are experiencing intermittent disconnections on the outside ASA interface which is connected to our ISP's 1841 router.
This is bringing down our remote VPN L2L connections
I have switched the interface to 100mb Full Duplex from auto to match the setting on the 1841 and I'm using a crossover but the issue still occurs with this error in the logs
"Line protocol on Interface Ethernet0/0, changed state to down"
The Interface and VPN then comes back up straight away but all RDP sessions running over our links are disconnected
Chris
shaw.chris Wed, 10/15/2008 - 11:57
Thanks, here are the Interface stats, seems to be OK
Interface Ethernet0/0 "OUTSIDE", is up, line protocol is up
Hardware is i82546GB rev03, BW 1000 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
MAC address xxxxxxxxxxx, MTU 1500
IP address x.x.x.x, subnet mask 255.255.255.240
6850202 packets input, 5812329681 bytes, 0 no buffer
Received 4410 broadcasts, 0 runts, 0 giants
3 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
6628378 packets output, 4889643034 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max packets): hardware (2/21) software (0/0)
output queue (curr/max packets): hardware (0/5) software (0/0)
Traffic Statistics for "OUTSIDE":
6850193 packets input, 5679324994 bytes
6628383 packets output, 4756896907 bytes
18704 packets dropped
1 minute input rate 31 pkts/sec, 3012 bytes/sec
1 minute output rate 39 pkts/sec, 34197 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 34 pkts/sec, 15824 bytes/sec
5 minute output rate 31 pkts/sec, 12659 bytes/sec
5 minute drop rate, 0 pkts/sec
Control Point Interface States:
Interface number is 1
Interface config status is active
Interface state is active
