FAX PRI E1 and FXS local on CME
Oct 15th, 2008
we have a cisco 3825 with cme 7.0.
On the router is a e1 and some fxs ports installed. Now we have some trouble with a fax.
Networkclock is fine, no slips!
card type e1 0 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
voice service voip
fax protocol pass-through g711alaw
controller E1 0/0/0
pri-group timeslots 1-31
description E1 ISDN PRI PSTN
voice-port 0/0/0:15
translate calling 2
translate called 1
no comfort-noise
cptone DE
voice-port 0/1/0
cptone DE
timeouts ringing infinity
station-id name Fax
station-id number 360
caller-id enable
My question:
When pri e1 and fxs is local, is something needed to configure for optimal fax working.
I am not shure how to see tdm hairpining is working.
Best was sg3 compatible.
A samle config was fine!
Have anyone this isue:
When we send a fax out the machine tell success but the other side receive nothing(blank side). How is this possible.
Every information is welcome.
Sebastian
Anonymous (not verified) Tue, 10/21/2008 - 08:04
Disable fax relay, disable echo cancellation, and force the call to use a high bandwidth codec without VAD. Disable VAD on the VoIP dial-peers it is enabled by default.
s.zink Tue, 10/21/2008 - 22:59
thank you for your replay.
I worked an this with the tac.
It seems that we have a fax that dosent work 100 percent with the cisco fxs ports.
I try it now with a internal bri port for the fax and take a TA to connect the fax.
Sebastian
