DCERPC Inspect Maps - ASA 5550
Oct 15th, 2008
I require some assistance with how to set up DCE RPC, the configuration I have has been applied through ASDM 6.1(5) and the ASA 8.0(4).
I have tried a couple of approaches;
1) Created an inspect map for DCERPC (ASDM)
2) Added DCERPC to the default inspection Service policy Rule(ASDM)
3) Copying an example from Cisco.com on the CLI
RPC connectivity works when allowing high ports in the Access Rules but not when only permitting tcp/135 which suggests the policy does not work. What am I missing? Is there other configuration to be completed with in the access rules?
Many thanks in advance
Richard
Anonymous (not verified) Tue, 10/21/2008 - 13:43
This is because by default all traffic from a higher-security interface to a lower-security interface is allowed. Access lists let you either allow traffic from lower-security interfaces, or restrict traffic from higher-security interfaces.
The security appliance supports two types of access lists:
• Inbound-Inbound access lists apply to traffic as it enters an interface.
• Outbound-Outbound access lists apply to traffic as it exits an interface.
The following URL explains in steps about configuring access rules using ASDM 6:
http://www.cisco.com/en/US/docs/security/asdm/6_1/user/guide/aclrules.html#wp1046058
vinerichard Tue, 10/21/2008 - 23:32
I'm not too sure how this actually related to my issue of DCERPC traffic and configuration of this functionality?
suschoud Tue, 10/21/2008 - 16:15
  • Gold, 750 points or more
class-map inspection_default
match default-inspection-traffic
exit
policy-map global-policy
class inspection_default
inspect dcerpc
exit
exit
Sushil
