Cisco IP Phone 7942/7965/7975
Oct 15th, 2008
Do these models support the following features:
Authentication
Voice and Signaling encryption
802.1X
Specific plug which permits the connection of different accessories.
separate amplified headset
Blue Tooth support
Chris Deren Wed, 10/15/2008 - 19:52
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Authentication - Yes
Voice and Signaling encryption - Yes
802.1X - 802.1X is wireless authentication protocol, not applicable here
Specific plug which permits the connection of different accessories. - the phones have PC switchport as well as RS232 port, and headset ports
separate amplified headset - typically not recommanded and not needed, but may be used if supported
Blue Tooth support - not yet.
HTH, please rate all helpful posts!
Chris
