Datacenter design
Oct 15th, 2008
In my datacenter I want to use 2960 as access layer and also i am runing multicast applications.. pls suggest me..
sateesh
vmoopeung Tue, 10/21/2008 - 10:32
As you are using multicast application you can configure Internet Group Management Protocol (IGMP) snooping on the Catalyst 2960 switch, which includes an application of local IGMP snooping, Multicast VLAN Registration (MVR). You can also configure IGMP filtering for controlling multicast group membership and you can also configue IGMP throttling action. With the IGMP throttling feature, you can set the maximum number of IGMP groups that a Layer 2 interface can join.
The following URL helps you to configure IGMP snooping, IGMP filtering and IGMP throttling in 2960 switch:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swigmp.html#wp1027678
