Converting 1250 APs between autonomous and LWAPP
Oct 15th, 2008
It took me a while to get this information, so thought I'd share. Here it is:
You cannot use the upgrade tool to do the IOS to LWAPP for the 1250 APs.
Here is a method to do the conversion.
*Method 1 : ( Mode Button )*
1. Install an external TFTP tool such as tftpd32 tool from http://tftpd32.jounin.net/
2. Assign IP address in the range 10.0.0.x ( Ex : 10.0.0.3)to the server.
3. Download the IOS to lwapp image onto the tftp's root directory. Use http://www.cisco.com
4. Make sure you set the IP address on the BVI interface of the AP if
not set.Set it in the 10.0.0.x range.
5. Connect the Ethernet port on AP to your TFTP Server ( Laptop )
5. Hold the mode button and power off the AP.
6. Power back the AP while continually holding the mode button for 20-30
seconds.
*Method 2 : ( Archive Command )
*1. Install an external TFTP tool such as tftpd32 tool from http://tftpd32.jounin.net/
6. On AP, type archive download-sw /overwrite /force-reload tftp://192.168.5.210/c3201-k9w7-tar.124-3.JK2.tar
Going the other way (lwapp to autonomous)
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
If you need to manually "prime" the LWAPP:
AP#lwapp ap ip address <IP address> <subnet mask>
AP#lwapp ap ip default-gateway <IP-address>
AP#lwapp ap controller ip address <IP-address>
AP#lwapp ap hostname <name>
(optional)
Hope someone finds this useful!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
