AIP SSM w/ Failover
Answered Question
Oct 15th, 2008
Hi all,
I will setup a module AIP SSM with failover active/standby. Did someone do this configuration? The active ASA will replicate the IPS config to the standby ASA? I look for some documentation on cisco site but I not found.
Correct Answer by abinjola about 8 years 5 days ago
Unlike ASAs..SSM Modules do not replicate there configs to each other..they are treated as separate units have to manually confgure both the Modules
See if this helps !
Overall Rating: 5 (1 ratings)
Loading. Thu, 10/16/2008 - 10:56
It`s very bad, because all config that I do in a module a will need to do the same config to each other... =(
But thank you a lot for you answer!!!
