1811W Broadcast multiple SSIDs
caplinktech
Is it possible to broadcast multiple SSIDs with an 1811W ISR? Everywhere I have searched I have found a reference to the "mbssid" command, however, it does not appear my IOS has that command. Does the 1811W support this and what IOS would be needed?
edward.weir
What IOS are you running? I'm running:
edge-1811w#sh ver
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(15)T1, RELEASE SOFTWARE (fc2)
edge-1811w#conf t
Enter configuration commands, one per line. End with CNTL/Z.
edge-1811w(config)#interface Dot11Radio0
edge-1811w(config-if)#mbssid
12.4(6)T I believe, maybe I need to upgrade.
