Limiting bandwidth on a interface
Joseph W. Doherty Wed, 10/15/2008 - 18:03
Outbound, you could shape or police your traffic to 3 Mbps. (Although, if possible, I would suggest you use CBWFQ and define 50% bandwidth for both you and the other party. This would allow either of you to use more bandwidth if the other party wasn't using their bandwidth, but both would get 3 Mbps if you both wanted it.)
Inbound is a problem, unless you control the outbound on the other side of the link.
Joseph W. Doherty Thu, 10/16/2008 - 06:25
NB: Syntax likely incorrect.
ip access-list extended mytraffic
remark match against your traffic source addresses
permit ip x.x.x.x y.y.y.y any
class-map mytraffic
match access-group mytraffic
class-map theirtraffic
match any
policy-map split5050
class mytraffic
bandwidth remaining percent 50
class theirtraffic
interface serial #
service-policy outbound split5050
If your still want to limit your bandwidth, even when excess is availble. You could do this.
policy-map restrictbandwidth
class mytraffic
shape average percent 50
class theirtraffic
interface serial #
service-policy outbound restrictbandwidth
