Max connection on Meet Me Conference
Answered Question
Oct 15th, 2008
Is anyone know what is the maximum allowed connection on a single Meet Me Conference number?
Thanks.
Dat Pham
Correct Answer by Chris Deren about 8 years 3 months ago
Keep in mind that software conferencing will work only with G711 codec, and transcoders would be required to allow G729 streams to be mixed.
Alos, the default max meet-me participants number service parameter is 4, so you would have to change it to get your desired number.
Chris
Correct Answer by Jaime Valencia about 8 years 3 months ago
Hw= hardware
CFB = conference bridge
SW = software
java
Overall Rating: 5 (2 ratings)
Jaime Valencia Wed, 10/15/2008 - 16:25
if using SW CFB recommendation is not to go over 48 even though it lets you go as far as 128. if using HW CFB usually the limit will be 8.
java
if this helps, please rate
phamvinhdat Wed, 10/15/2008 - 16:29
Thanks HTH,
Can you clarify on HW CFB and SW CFB? I am not familar with those?
Thanks.
Dat Pham
Correct Answer
Chris Deren Wed, 10/15/2008 - 20:01
Chris
phamvinhdat Wed, 10/15/2008 - 20:12
Thanks Chris,
I will check on the service parameter setting.
Dat Pham
