ADSL Load balancing+redundancy
Oct 15th, 2008
HI all,
I am using the setup 2ADSL line terminated the 2800 router, it is working fine.
I am facing a problem incoming connection.
1)Webmail connection accessing from outside .
2) if we shutdown 1 diler interface i can access the webmail.
I am attaching the configuration and suggest the changes in config.
Haris P Tue, 12/02/2008 - 00:15
Dear Subsh ,
You can use the OER concept to make load balancing and failover with two ISP's . 2811 will work without any problem if the IOS is 12.4(15)T .I myself used this idea to make load balancing between leased line and DSL for one of my customer and it's really beautiful
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
Haris
