IP Duplication issue on all vlan
Oct 15th, 2008
Plz find the error message
*Oct 15 08:26:19: %IP-4-DUPADDR: Duplicate address 10.205.124.2 on Vlan6, sourced by 0009.6b99.982e
Plz reply on urgent
massimiliano.se... Thu, 10/16/2008 - 00:59
Error Message
%IP-4-DUPADDR : Duplicate address [int] on [chars], sourced by [sci_notation]
Explanation Another system is using your IP address.
Recommended Action Change the IP address of one of the two systems.
Reference:http://www.cisco.com/en/US/docs/ios/12_0/system/messages/emflash.html#wp1026166
Check to see if you have another network devices with the same mac address.
I hope this helps.
Best regards.
Massimiliano.
tarunavakonar Thu, 10/16/2008 - 01:14
no
is there any another issue is possible
it is happening on every vlan's gateway address
sirdudesly Thu, 10/16/2008 - 01:22
have you looked at what device is triggerign the message (based on hardware address)
Pravin Phadte Thu, 10/16/2008 - 01:49
Is there any DHCP configured ?
If so you may need to check the settings and reduce the lease time
Hope this helps
