PIX QOS
Oct 16th, 2008
I am looking to configure QOS on my PIX running version 8.03 of the PIX software.
I would like to give priority to VPN tunnel traffic as well as certain other designated traffic, based on an acl. Ideally, I wouldn't want to police all other traffic by rate-limiting it.
My current config looks like this:
access-list acl_priority permit ip host external_ip any
class-map priority_traffic
match access-list acl_priority
class-map vpn_traffic
match tunnel-group x.x.x.x
policy-map priority_traffic
class priority_traffic
priority
class vpn_traffic
priority
service-policy priority_traffic interface outside
The thing I am unsure about is do I need to apply rate limiting (policing) under the default class or can I just leave it like this? Does the priority queue take as much bandwidth as it needs to? Also, with the above config, is traffic policed in the outbound direction only?
What I am hoping to acheive is, if the WAN connection is being hammered by large downloads, I would want the priority traffic to take precedence.
Marwan ALshawi Thu, 10/16/2008 - 05:18
first u need to enable the Priority queues on the physical interface with the command
priority-queue if_name
Priority queues are supported only on physical interfaces that have been configured with the
nameif command. Trunk interfaces and other logical interfaces are not permitted to have a
priority queue. Also, priority queues are not supported in multiple-security context mode
As soon as the priority queue is enabled for the first time, the queue limit is set to a
calculated default value. The limit is the number of 256-byte packets that can be transmitted
on the interface over a 500-ms period. Naturally, the default value varies according to the
interface speed, but it always has a maximum value of 2048 packets
Packets in the priority queue are serviced and sent out before any packets from
the normal queue. Therefore, the priority queue is not affected by the volume or types of traffic
contained in the normal queue. The priority queue can be used to provide premium service to
delay- and jitter-intolerant applications such as streaming video and voice
good luck
if helpful Rate
alraycisco Thu, 10/16/2008 - 07:39
Thanks for the reply.
Sorry I forgot to add that I'd enabled the priority queue on the interface.
The traffic I'm wanting to give priority to isn't delay and jitter intolerant, it's just traffic that I don't want to be affected by other internet traffic.
So with the example of the ACL, would the traffic that is natted to that public IP receive priority over all other internet traffic? How are uploads affected vs downloads?
Your help is much appreciated.
