snmp linkup/linkdown traps not being sent to the snmp server
Oct 16th, 2008
Hi All,
I have configured the Cisco 6509 to send all the snmp traps to the NEtact snmp server. I get the config change traps being sent to the server. But when I plug and unplug my laptop to a Gigabit interface I do not get any traps.
I am able to see the linkup and linkdown logs on the console but not on the snmp server.
Hardware:
PACO-C6509
Software Version:
12.2(18)SXF10
logging snmp-authfail
snmp-server community xxx RO 15
snmp-server community yyy RW 15
snmp-server trap-source Vlan401
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps chassis
snmp-server enable traps module
snmp-server enable traps transceiver all
snmp-server enable traps casa
snmp-server enable traps tty
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps bgp
snmp-server enable traps config-copy
snmp-server enable traps dlsw
snmp-server enable traps event-manager
snmp-server enable traps frame-relay
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps MAC-Notification move threshold
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps rf
snmp-server enable traps rtr
snmp-server enable traps slb real virtual csrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps flex-links status
snmp-server enable traps sonet
snmp-server enable traps dial
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps rsvp
snmp-server enable traps srp
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps c6kxbar intbus-crcexcd intbus-crcrcvrd
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps csg agent quota database
snmp-server enable traps port-security
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls ldp
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps alarms
snmp-server enable traps vlan-mac-limit
snmp-server enable traps voice poor-qov
snmp-server enable traps mpls vpn
snmp-server host 10.x.y.17 public
snmp-server host 10.x.y.23 public
Please let me know if you have come across this kind of an issue before.
DO i have to configure anything under the interface mode?
Please let me know.
This is the sample interface configuration:
interface GigabitEthernet1/44
description SW1-Netact Port 0/18 QTSGSN1-OM-to-NetAct-Router-1
switchport
switchport trunk allowed vlan 400,401
--More-- switchport mode trunk
switchport nonegotiate
no ip address
speed 100
duplex full
singhsaju Thu, 10/16/2008 - 07:33
Under interface for specific interface: snmp trap link-status
http://www.cisco.com/en/US/docs/ios/12_0/configfun/command/reference/frmonitr.html#wp1023375
Also in newer IOS
The snmp-server enable traps snmp [ linkup] [linkdown] form of this command replaces the snmp trap link-status interface configuration mode command.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094a05.shtml
Saju
Pls rate helpful posts
