port redirection
Oct 16th, 2008
I want to do port redirection for my inside users(port no 8888) to web server in DMZ(port no 80).
Case 1:Inside user types in browser http://192.168.101.10:8888
Case 2: http://mywebserverurl:8888
Inside n/w 192.168.100.0 DMZ n/w 192.168.101.0
I have done the same for internet using static (inside,outside) tcp ... command.And it is working fine.
singhsaju Thu, 10/16/2008 - 12:56
  • Silver, 250 points or more
can you check if its 192.168.101.10 or 192.168.100.10 in the following statement?
if your statement is correct then try using following statement:
static (dmz,inside) tcp 192.168.101.10 8888 192.168.101.10 80 netmask 255.255.255.255
Farrukh Haroon Sun, 10/19/2008 - 00:11
  • Red, 2250 points or more
You can use the static command or the alias command to do port redirection on the ASA. However the one suggested by singhsaju is the better/new way to do it.
Farrukh
