NM-2CE1-T1-PRI not working on C2811!!
Oct 16th, 2008
My module is not working under cisco 2811 router. I found the interfaces in the "sh ver" but when I want to use the card (card type e1) this not works
Here bellow sh ver
What should I do to enablethe module
OTA96#sh ver
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3i), RELEASE
SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 21:09 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
OTA96 uptime is 1 minute
System image file is "flash:c2800nm-ipbase-mz.124-3i.bin"
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Processor board ID FCZ12237337
2 FastEthernet interfaces
2 Channelized (E1 or T1)/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
OTA96#card type ?
% Unrecognized command
OTA96#card ?
OTA96#card
Overall Rating: 3 (1 ratings)
tarik.fakir Thu, 10/16/2008 - 04:29
Hello Sushil,
But the command not working (this is the root of our problem), the command not exists!!
OTA96(config)#car?
carrier-id
OTA96(config)#car
tarik.fakir Thu, 10/16/2008 - 07:08
1 more detail
I'm getting this message when the router start up
*Mar 1 00:00:15.391: %ET2_MODULE-3-INITFAILURE: ET2 (slot 1), PCI initialization failed at ../nms/ernest_t2/nms_et2.c - line 1067 arg 0 -Process= "Init", ipl= 3, pid= 3 -Traceback= 0x8115B5DC 0x805AC31C 0x805AC814 0x8028D590 0x8028D700 0x8222B8DC 0x81152DE8 0x811530C8 0x8023C990 0x80240094
Is the module faulty?
B.R
Edison Ortiz Thu, 10/16/2008 - 09:56
It looks like a faulty module, I recommend opening a TAC case for further troubleshooting.
HTH,
__
Edison.
