problem installing cm 4.0.5
Oct 16th, 2008
I'm installing cwcm4_0_5_sol on LMS 2.5.1 and I get this error:
"cat: cannot open /tmp/cscotmp/new.depend
ERROR(978): Fatal error: File /opt/CSCOpx/databases/rmeng/rmeng.db does not exist.
Backup failed: 2008/10/16 11:28:51
expr: syntax error
ERROR: needsMoreDiskSpace called with insufficient arguments."
On the test-server the installation runs without errors, but the network is smaller.
The rmeng.db exists und is 4G big
on the /opt partition where CW is installed there is still 27G free space
Can some one help
Joe Clarke Thu, 10/16/2008 - 06:42
A database > 2 GB should not be a problem if you have Common Services 3.0.3 or higher. What do you get when you run:
/opt/CSCOpx/bin/logrot_stat /opt/CSCOpx/databases/rmeng/rmeng.db
Joe Clarke Thu, 10/16/2008 - 06:52
I know this is fixed in LMS 2.6. You might try skipping the Campus 4.0.5 update, and go straight to LMS 2.6. However, if you open a TAC service request, more analysis can be done of the code already on your system.
angelapreta Thu, 10/16/2008 - 07:05
on an other server I have installed this update, after the error I continued the installation.
It works since yesterday, and all features: discovery, data collection, UT and the topology services are working at the moment fine.
What happens if he can't backup the rmeng.db during the installation?
Joe Clarke Thu, 10/16/2008 - 07:08
Nothing if the installation goes well. The purpose of the backup is to give you something on which you can fallback if something goes wrong in the IDU installation. If the IDU is successfully installed, then you wouldn't need a backup.
That said, if your regularly scheduled backups are failing, that needs to be investigated. You should not be running without known good backups.
angelapreta Thu, 10/16/2008 - 07:23
do you mean the backup from the application Common Service?
The backup last night was completed, have no error found in the dbbackup.log but when I check the backup I have found this /opt/CSCOpx/backup/1177/rmeng/database/rmeng.db with 2.5G size, is this correct?
Joe Clarke Thu, 10/16/2008 - 07:29
Yes, I mean the Common Services backup. If the log indicates that the rmeng database was successfully backed up, then you are probably okay.
