Antivirus enabling causes cti route points to unregister
Oct 16th, 2008
We have mcafee 8.0 antivirus on CCM server installed. When we enable the antivirus, at the time of antivirus update all the CTI route points (QM, PG etc) get unregistered and agents also get logged out. What can we do so that after enabling the antivirus, this issue will not happen?
Overall Rating: 4 (1 ratings)
tim.giles Thu, 10/16/2008 - 06:07
  • Silver, 250 points or more
You could change the AutoUpdate configuration so the antivirus only updates at 2am (or out of working hours). That way it will affect users less.
You can also configure the On-Access scanner to Exclude the CCM directories so it doesn't affect call processing.
You could also disable both options (AutoUpdate and On-Access)..
Please rate useful posts..
K_require Thu, 10/16/2008 - 08:36
Thanks. Can you please let me know which CCM directories?
