CWLMS 3.0 Not able to install applications after patching another app.
Answered Question
Oct 16th, 2008
I think a have this bug. I done the workaround but I can't fix the error at all.
bug : CSCsj94584:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsj94584
follow the workaround carefully:
1. Modify the .info files for the patched modules under NMSROOT/setup and
set the value of PATCHVER in these files to their original value of 0.
cmf.info
cvw1.info
nmim.info
cdone.info
rme.info
cwa.info
portl.info
2. Install the new application on CiscoWorks Server.
3. Reset the values of PATCHVER to their original patched versions after the installation is complete.
I do the 3 steps, I modified all this files , but the file "nmim.info” doesen't exist.
Now when I put the installation DVD , this situation improved, only get the error with the CiscoView module.
Pleaseeee, can tell me whats wrong?
best regards!
Correct Answer by Joe Clarke about 8 years 7 months ago
You shouldn't set the PATCHVER in cvw1.info to 0. The LMS 3.0 CVW version is 6.1.6, so the PATCHVER should be 6. You really should contact the TAC, and have them help you with this as not to mess up your installation.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 10/16/2008 - 06:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
expe_0626 Thu, 10/16/2008 - 11:05
I have to restart the server? or asign 6 to this file?
thanks!
best regards
Joe Clarke Thu, 10/16/2008 - 11:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You do not need to restart anything per se. The installation occurs with Daemon Manager shutdown anyway. It's just that the PATCHVER for CVW needs to be 6 for LMS 3.0.
expe_0626 Thu, 10/16/2008 - 12:14
Hi Jclarke!
Thanks very much. I can fix the problem, changeing the PATCHVER number. Thanks again!
best regards!
