Unable to clear port-security sticky
Answered Question
Oct 16th, 2008
Hi all,
I am using the command:
switchport port-security mac-address sticky to set port security.
On one of my IOS switch I am unable to clear the sticky MAC address using the command:
clear port-security sticky int fa 0/1.
Is there another way to achieve without having to upgrade IOS?
Thanks.
Correct Answer by julieglass about 8 years 9 months ago
simply put 'no' in front of that command
no switchport port-security mac-address sticky [mac-address]
it will clear the captured mac
Correct Answer by Hieu Cao about 8 years 9 months ago
The command given by Earnest basically removes the previously set/seen mac-add in that switch port.
Your port security is still enabled though provided that you've this command "switchport port-security" in place.
The port security sticky option is still enabled if you have this command "switchport port-security mac-address sticky" in the switch port.
Overall Rating: 5 (3 ratings)
ece344609_2 Fri, 10/17/2008 - 08:56
Thanks Ernest.
What exactly will that command do? I dont want to shut off port security, just wanted to clear the MAC address so the port does not shutdown when the next machine is plugged in.
Correct Answer
Hieu Cao Fri, 10/17/2008 - 09:47
Correct Answer
julieglass Fri, 10/17/2008 - 10:22
