Oct 16th, 2008
I have CallManager 6.1.1 and I am trying to install CiscoTSP and the wave driver to provide click to dial functionality. The logs show "directory login failed" and I am positive I am using the right username and password (same one I use on ccmuser). I have even tried the Netelligent product and have not been able to get that to work either.
Are there changes within CallManager that need to be made? Services? Permissions?
tim.giles Mon, 10/20/2008 - 01:28
Have you made sure this user is in the Standard CTI Enabled group in CallManager?
CLIFFORD BECKER Mon, 10/20/2008 - 07:16
Yep. The user is in the Standard CTI Enabled group.
I have tried to restart the CTI services with no luck as well.
tim.giles Mon, 10/20/2008 - 09:36
Ok cool.
Is the phone associated with this user and does it also have "Allow Control of Device from CTI" enabled?
CLIFFORD BECKER Mon, 10/20/2008 - 10:14
The phone is associated with the user and it does have "Allow Control of Device from CTI" enabled
