robotic soung on ipcc recorded call
GleidsonG
Hello everyone.
I have the following problem:
I have a CCM 4.1(3)sr7 and IPCC 3.5(2).
The calls are recorded using a workflow and everything was working fine.
Some day ago the voice quality is very poor and robotic.
Can anyone help?
Thank you
Gleidson CCVP
Nexa - Brazil
mikram
Level 4
Level 4
Hi Gleidson,
Could you please check your network switches if something has changed. Check for any network errors and LAN Card.
cheers
Ikram
Hello mikram.
This is the port status
SW01#sh run | b sess
monitor session 2 source interface Gi0/2 rx
monitor session 2 source vlan 34 rx
monitor session 2 destination interface Fa0/16 ingress vlan 34
end
SW01#sh inter fas 0/16
FastEthernet0/16 is up, line protocol is down (monitoring)
Hardware is Fast Ethernet, address is 0011.5c3e.1010 (bia 0011.5c3e.1010)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 3/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:15, output 23:06:11, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 1445000 bits/sec, 829 packets/sec
2125410 packets input, 168098794 bytes, 0 no buffer
Received 40242 broadcasts (0 multicast)
1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 27139 multicast, 0 pause input
2101432444 packets output, 3905105117 bytes, 11334531 underruns
0 output errors, 0 collisions, 1 interface resets
11334531 output buffer failures, 0 output buffers swapped out
