CALL TYPE batch changes (all at once)
david.macias Thu, 10/16/2008 - 12:57
Nope, I would do it through the config manager and not the script editor though, might prove a little quicker. Good luck.
david
david.macias Thu, 10/16/2008 - 13:18
Actually, re-reading what you posted it might not help. In the config manager you can assign a call type to a dialed number. However, it sounds like the dialed number will stay the same, in your case, it's the script that's actually changing.
david
Md. Mijanur Rahman Fri, 10/17/2008 - 05:53
If other parameters (like association with DN etc) are exactly like the older ICM, then you can modify your Call_Type table,that's easier than changing from config manager. What the problem?
david.macias Fri, 10/17/2008 - 07:33
You're a brave man if you do this, I'm always leering about changing thinks in the DB.
dam
Md. Mijanur Rahman Fri, 10/17/2008 - 07:55
lol
I didn't check the thing exactly what are you looking for, but i did some changes in the db directly before and found no discrepancy.
Even I did had to work in the db directly for some scenarios like: I added a DN from config manager; then for some reason I deleted it, it was deleted successfully, but I failed to add the same DN from config manager again. Then I found the same in the DB with disabled flag, the I deleted the entry from DB forcefully. Even I have also added agents from DB directly.
You should add entries over there when dependence parameters are there already.
