How do I distribute a default route?
Oct 16th, 2008
Running EIGRP.
See attachment.
I need to make the default route, from all routers, get to my firewall. If something fails in the ring I want it to fail over and still be able to reach the firewall.
Scenario: Using static default routes, router 4 has a primary of C and a secondary of D.
Router 5 has primary of E and secondary of D.
Router 6 fails.
Router 5 uses secondary route of D but router 4 still has primary of D. Traffic just bounces back and forth.
Is there another way to do default routes without using static?
Giuseppe Larosa Thu, 10/16/2008 - 13:15
  • Hall of Fame,
    Founding Member
Hello Paul,
EIGRP supports a specific command that is ip default network: actually an EIGRP route is flagged as capable to support a default route and propagated in the EIGRP domain.
In your case the link is the R1 -FW link
requirements:
ip subnet on R1-FW must be in a different major network not subnetted
a network command for this subnet must be present in R1 router eigrp config
see
http://www.cisco.com/en/US/docs/ios/iproute/configuration/guide/irp_ip_prot_indep_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1056287
note: you still need a default static route on R1 pointing to FW
Hope to help
Giuseppe
